M40 Timing Belt Change
Revision as of 20:50, 18 July 2008 by 91.106.12.60 (talk)
M40 Timing Belt Change (Originally Submitted on the E30 Zone by Gwynleym10 Please visit [1] to see his charity drive from London to Cape Town)
Please note that this car had air - con so ignore the extra pipes / slightly bigger radiator + compressor.
Take the fan cowling off:
Pile of bits...
Old belt:
I then changed the rollers and then tensioners this is so obvious how to do it - you undo the bolts! Re-fit a new belt belt:
Starting from the bottom:
Tighten it up:
Fitting is the reverse of removal.....!
