Building a 2.7
Revision as of 06:25, 8 December 2009 by 24.130.171.46 (talk)
The 2.7 ETA ENGINE
Early Etas up until Sept. 1985 had a compression ratio of 11:1. The blocks of these engines is stamped 27 6KA. From 9/86 the compression ratio was dropped to 10.2:1 and these engines are stamped 27 6EB. These numbers are stamped above the main engine number. BMW dropped the CR due to detonation issues on 95RON - no knock sensors back then!
  • Retain the standard Eta bottom end untouched and fit a head from an E30 320i or 323i. This is the 731 head which has much bigger inlet ports than the 200/Eta. It has the same sized valves as the Eta which are 40mm inlet and 34mm exhaust. The combustion chambers are identical the Eta 200 head so by fitting a 731 head, you will retain the Eta compression ratio.
  • Use the standard Eta bottom end with a 325i head, the 885 unit. The 325i has strange pistons with a deep dish but a raised section at the front of the combustion chamber to accommodate it. Despite what experts say, the 325i head will NOT give a horribly low compression ratio. The difference in chamber volume is quite small. The 325i head has a chamber volume of @ 42.5cc and the 731 and 200 heads have a chamber volume of @38cc. It all depends on whether the head has been skimmed. But 4.5cc difference isn't much at all and much of the increased size of the 325i chamber is made up for by the bigger valves and surrounding raised areas around them. 325i valve sizes are 42mm inlet and 36mm exhaust.
  • Using 325i pistons with a 325i head. This is the best way of doing it but requires a complete engine strip down.
          • There is another alternative if you have a "super eta" (which is a 1988 325, badged 325 on the trunk and says 325e 10/87 or later on the sticker in the door)
Other stuff:
ECU etc
The ECU will need remapping. A 2.7 engine will have faster piston speed meaning it will get to the top of the bore and point of ignition faster - over a 325i, the piston has an extra 6mm to travel in the same amount of time (one crank revolution), requiring a change in ignition timing. Also, the long stroke increases the piston dwell at TDC. It willl need more fuelling too.
Spark Plugs
Crank
Cylinder Heads
TDC Sensor
Cams
