Grille Variants
Revision as of 00:06, 10 July 2010 by 217.153.102.184 (talk) (Grilles)
http://www.orderlevitrapills.com/ levitra >:[[[ http://www.buypropeciahere.com/ propecia viagra %] http://www.skincaremedication.net/ online pharmacy accutane 90351 http://www.phentermine-hcl.org/ phentermine 8066
Retrofitting
The grilles use the same mounting points, and are completely interchangeable. It is a good idea, if attempting to swap the grilles, to replace the foam strip along the top edge, replace all the clips, and clean the exposed inside edge of the metalwork.
