Building a 2.7
Revision as of 08:39, 15 July 2008 by Hoshy (talk | contribs) (New page: This is how it is done. No ifs, buts, what ifs or how abouts. It is all here in plain English. The 2.7 ETA ENGINE These arrived in 1983 to power the 525e and 325e (not UK) although the U...)
The 2.7 ETA ENGINE
Early Etas up until Sept. 1985 had a compression ratio of 11:1. The blocks of these engines is stamped 27 6KA. From 9/86 the compression ratio was dropped to 10.2:1 and these engines are stamped 27 6EB. These numbers are stamped above the main engine number. BMW dropped the CR due to detonation issues on 95RON - no knock sensors back then!
1.) Retain the standard Eta bottom end untouched and fit a head from an E30 320i or 323i. This is the 731 head which has much bigger inlet ports than the 200/Eta. It has the same sized valves as the Eta which are 40mm inlet and 34mm exhaust. The combustion chambers are identical the Eta 200 head so by fitting a 731 head, you will retain the Eta compression ratio.
2.) Use the standard Eta bottom end with a 325i head, the 885 unit. The 325i has strange pistons with a deep dish but a raised section at the front of the combustion chamber to accommodate it. Despite what experts say, the 325i head will NOT give a horribly low compression ratio. The difference in chamber volume is quite small. The 325i head has a chamber volume of @ 42.5cc and the 731 and 200 heads have a chamber volume of @38cc. It all depends on whether the head has been skimmed. But 4.5cc difference isn't much at all and much of the increased size of the 325i chamber is made up for by the bigger valves and surrounding raised areas around them. 325i valve sizes are 42mm inlet and 36mm exhaust. A lot has been said about Eta pistons being incompatible with the 325i head. Most of it is nonsense as this has been done many times and it works okay. Of course it won't give results quite as good as using the matching 325i pistons but it still has a good compression ratio which is most of the battle won.
3.) Using 325i pistons with a 325i head. This is the best way of doing it but requires a complete engine strip down. Doing this, the pistons of course match the head. Compression ratios will be 9.4:1 using post 9/87 (plastic bumper) 8.8:1 CR pistons and 10.4:1 using the early pre 9/87 (steel bumper) 9.75:1 CR pistons. Why the higher CR in a 2.7? Because it has an extra 49.8cc of fuel/air mixture to compress.
Other stuff:
ECU etc: You will need a complete 325i Motronic set up. ECU, inlet manifold with injectors, air flow meter. Good news if you already have a 325i.
The ECU will need remapping. A 2.7 engine will have faster piston speed meaning it will get to the top of the bore and point of ignition faster - over a 325i, the piston has an extra 6mm to travel in the same amount of time (one crank revolution), requiring a change in ignition timing. Also, the long stroke increases the piston dwell at TDC. It willl need more fuelling too.
Head Gasket: Eta and 325i are the same. You can buy standard or thicker gaskets which will lower the compression.
Radiator: Is the standard 325i radiator okay? Yes, it's fine.
Spark Plugs: Which spark plugs? Bosch W7DCR or the NGK equivalent. The plastic bumper 325i uses W8€ plugs which are not quite right for a 2.7. 2.7 engines have higher compressions and higher compression ratios equal more heat, and you need a plug to dissipate the heat faster. The W7 is known to work.
Crank: UK 525e cars were autos and you need to fit a spigot bearing in the flywheel end of the crank.
Cylinder Heads: 731 or Eta heads do not work with 325i pistons because the raised crown would smack into the head and lock it up.
Sump: The E30 sump fits straight to an Eta block but you need 25 longer bolts because an alloy sump is thicker than a pressed steel one. The BMW part number is 07119915031.
TDC Sensor: Eta blocks have the two threaded holes to take the later Motronic front TDC sensor.
Cams: Be careful with your choice of cam. Wild 285 degree cams probably won't pass the hydrocarbons test.
Ant?
