Stripping and Rebuilding an M20 Cylinder Head
<<Work in progress>>
- Required Tools
- Female Torx Socket
- Old Timing Belt
- Lockable Grips
- 8mm Spanner
- 10mm Spanner
- 3mm Allen Key
- 11mm Deep 1/4" Drive Socket
- Feeler Gauges
- Valve Spring Compressor
- Hammer
- Magnetic Ended Screw Driver
- Spark Plug Wrench
Stripping the Cylinder Head Before doing anything else, it's preferable to place the head on a workmate or similar work bench with a gap in the middle because as you turn the valve train over, the valves will hit if you have it on a flat surface. Now remove the spark plugs with a suitable plug wrench.
[picture 1]
[picture 2]
[picture 3]
The next part of the procedure is to remove the rockers and shafts. I usually work with the pulley end of the head to my right. Concentrate on removing one rocker shaft at a time. We will be removing the exhaust side rocker shaft to begin with. Place the pulley bolt back into the end of the camshaft so that you turn the camshaft. Keep turning the bolt until it fully tightens.
[picture 4]
[picture 5]
[picture 6]
[picture 7] [picture 8]
[picture 9]
[picture 10]
[picture 11]
[picture 12] [picture 13]
