BMW Dealership Maintenance - Inspection 2
Revision as of 13:23, 29 June 2008 by Hoshy (talk | contribs) (New page: {{stub}} Please update with service intervals and other relevant information ==INSPECTION 2== The inspection two service Engine Compartment: * Check and adjust valve clear...)
INSPECTION 2
Engine Compartment:
     Check and adjust valve clearance (M20).
     Replace camshaft timing belt every other Inspection 2 or 50K miles.
     Inspect V-belt/Poly-ribbed drive condition, check tension (M20).
     Lubricate throttle linkage.
     Change Oil and oil filter.
     Change air filter or clean it if reusable (like K&N).
     Check battery acid level and correct if needed.
     Check Coolant level and inspect system for leaks.
     Check Steering fluid and brake/clutch level.
     Check windshield washer fluid level.
Undercarriage:
     Change automatic transmission fluid.
     Change manual transmission oil.
     Check clutch plate for wear.
     Check drive axle boots for leaks.
     Change final drive fluid (’95 change synthetic fluid every other Insp.II).
     Replace fuel filter.
     Check fuel lines, fuel tank and all connections for leaks.
     Inspect exhaust system.
     Check steering box and steering linkages for leaks and excess play.
     Inspect brake callipers, discs and brake pad thickness.
     Inspect brake hoses and lines for damage or leaks.
     Check handbrake, adjust cable if needed.
     Check thickness of parking brake linings.
     Inspect front suspension and wheel bearings for play.
     Inspect wheels, tyres and adjust tyre pressures.
     Check spare tyre pressure.
Body and Interior:
     Lubricate door hinges, bonnet latch and bonnet hinges.
     Check operation of exterior/interior lights (including glove box, engine compartment… ).
     Check headlight aiming.
     Check condition and function of seat belts.
     Check operation of washer system and wiper blade condition.
     Check active check control panel for faults.
     Check function of air conditioning. Check refrigerant charge at sight glass.
     Tighten A/C compressor mounting bolts.
     Tighten nuts and bolts for door locks and striker plates.
     Replace intake dust/pollen micro filter in A/C unit.
     Replace batteries for alarm/remote control in master key (’95 E34).
Road Test:
     Check braking performance, steering, HVAC, transmission and mirrors.
