Category:Incomplete Articles
Please note this is still in an "edit" stage, it should not be used until placed into the main forum.
Suggested changes/additions.. 1. tap and clean head bolt threads in block making sure they are cleaned right to the bottom of the thread- remove any muck in the bottom of the thread bore. 2. If using new rings, it is very important to check gaps in bores first before assembly onto pistons. 3. Torque up crank and check rotation and end float before assembling pistons/rods. 4. Detail how to install new oil ring onto piston and how to orientate all ring joints when installing into block.
Maybe mention (but not applicable for assembly of the M20 motor)- when installing piston/rod assembly, if the rods have studs, a sleeve must be placed over the stud to protect the crank journal from possible damage in the installation process.
Building a m20 6 cylinder engine... by Mike Jermyn
Honing.
Refaced.
Six brand new Mahle pistons.
Removing the circlip.
Once you get the first circlip in, you need to grease the piston and gudgeon pin with pre assembly lube.
