Category:Incomplete Articles
Building a m20 6 cylinder engine... by Mike Jermyn
Honing.
Refaced.
Now if you are using your old piston and rod combo you can skip this step.
Six brand new Mahle pistons.
Removing the circlip.
When them down be sure to use some anti seize on the threads. I don't torque them up- only nip them up.
