E36
Successor to the E30. Bigger and heavier, it came with up to a 2.8l engine, more advanced rear suspension, but it's just not as cool.
Compatible Parts
Engines
Main article: Engine Swaps
NOTE: The sump on all E36 engines must be changed to an E30-compatible equivalent. This is because the location of the oil pan interferes with the E30 subframe
Gearboxes can be fitted with their matching engines, but E36 gearboxes sit at a different angle to their E30 counterparts. This means that modifications must be made to the gearbox mount and shifter mechanism
Steering
The steering rack, specifically the model, is desirable for its faster turn rate. However, custom piping will be needed to overcome the differences in power steering plumbing.
Specifically from the 318 Compact, the rear beam including trailing arms is a direct bolt-on replacement for the E30 unit, and is commonly used when converting to a 5-bolt hub.
Front wishbones fit, but are inferior to E30 ones.
Interior
Many Seats can be made to fit, but nothing directly bolts in. Aside from that, only the electric window switches are easily fitted to an E30.
