E30 Dyno Graphs
M10
M1020 - teamalsoran 200.2 BHP 156.7 lbft
2.0 M10
Ported 121 head
12.1 CR
45mm jenveys
M1022 Turbo - teamalsoran 316.5 BHP 346.9 lbft
2.2 litre m10 turbo
Schrick 284 cam
T34 turbo
M10B25 - teamalsoran 240.7 BHP 207.2 lbft
-*Lower Graph*-
240bhp 2.5 litre m10
Custon Accratlie pistons in a 2.5 s14 bottom end
M10 121 head
12.1CR
Schrick 336 cam
50mm Jenvey throttle bodies
M20
M20B25
M20B25 - bss325i 185.7 BHP 196 lbft
M20B25 - Simon 183.7 BHP 191 lbft
Redline - Standard
M20B25 - clarko74 167.6 BHP 173 lbft
A-Tech Chip
180k Miles on the engine.
M20B25 - Hoobs 164.5 BHP 144 lbft
Standard
M20B25 - Hoobs 170.1 BHP 136 lbft
This is after a service & running a 'Speedtouch' wild chip and a 6 branch of unconfirmed origin
M20B25 - gaszman 163 BHP 171 lbft
Standard high comp prefaclift engine
M1.0 Motronic
m20b25 - hongkongfuey 192.1 BHP 189.9 lbft
stock 2.5
cam
bbtb (home made)
hottuning manni (no x pipe)
m30 injectors and afm
home made intake elbow
dmcl chip
lightened flywheel
M20B25 - nadz325i 189 BHP 173.5 lbft
BTB 6 Branch
BBTB
ITG INduction Kit
Schrick 284/272 CAM
Before MAF(with schrick, BBTB, 6 Branch and ITG);
180.6 bhp @ 6221 rpm
164.1 lb.ft @ 5314 rpm
After MAF;
189 BHP @ 6332rpm
173.5 lb.ft @ 5357 rpm
At the wheels figures.
M20B27
M20B27 - Simon13 198 BHP 217 lbft
Racing Dynamics 6 branch with full scorpion
198bhp and 220lbs
M20B27 - Oguz327 225.6 BHP 204.8 lbft
2.7 M20, fully lightened, balanced and blueprinted built by A Tech
285/285 cat camshaft
BTB 6 branch
BBTB
Rolling road remap
ITG filter
Full scorpion system
M1.3 Motronic + chip
M20B27 - Oguz327 (Megasquirt) 227.8 BHP 208.6 lbft
BTB 6 branch
BBTB
Rolling road remap
ITG filter
M20B27 - oakey 205.7 BHP 224 lbft
Standard head
Bexley Block
M20B27 - oakey 218.6 BHP 211.8 lbft
135mm rods
Alpina pistons
ETA crank
11.016:1 CR
ITBs
280/280 cat camshaft
mild head port
TPS only (Alpha-N algo)
M20B27 - Daimlerman 178.3 BHP 191 lbft
525e Block
731 Head
Miller MAF
M20B27 - Jimbob 200.4 BHP 199 lbft
525e Crank and Rods
High comp M20B25 pistons
325i block decked
Standard 325i head
Dbilas 284/272 with standard springs
BTB 6 Branch
A-Tech Chip
M20B28
M20B28 - Bullet_Ride 182.6 BHP 193.8 lbft
Schrick 284 with stock valve springs.
Block shaved 0.5mm
On a hot summer day with the car running rich because of a bad O2 sensor this is what I put down...
M20B28 - stonesie 206 BHP 203 lbft B25 low comp pistons, block and head both skimmed (minimal on the head, 0.5mm on the block to retain standard squish) approx 9.7:1 CR
M52B28 crank
M20B20 rods
CatCams 273/273 with vernier
Lightweight flywheel
BBTB
M20B28 - goosiegander 195.4 BHP 175.4 lbft
M20 2 ltr block bored to 84.0mm
Single vanos M50B28 crank
M20 2 ltr conrods
885 headcasting
BBTB
2.8 Motronic chip
M20B28 - goosiegander 200 BHP 190.1 lbft M20 2 ltr block bored to 84.0mm Single vanos M50B28 crank M20 2 ltr conrods M20 2.5 facelift (low comp) pistons Catcam 285/285 degree camshaft 885 headcasting BBTB Hottuning 6 branch and scorpian system MAF Conversion
M20B31
M20B31 - reggid 220 BHP @ wheels 218 lbft @ wheels
M20B31 - 3086cc
10.5:1CR
BTB2
BBTB
standalone
catcams 298/285
M30
M30B35 - driftmonkey 206.5 BHP 213 lbft
Standard
M30B35 B10 Alpina- leeparkes 257 BHP 285 lbft
Alpina B10
M5 conrods
Larger valves
268 degree cam
Remapped ECU
M30B35 Turbo- Toby_Unna 295.6 BHP 330 lbft
Turbo Conversion
Megasquirt
M40
M42
M42B18 - agreen 147.6 BHP 136 lbft
Green line Standard
Pink line with Evolve Automotive chip fitted
M42B18 - Magpie 152.0 BHP 135.8 lbft
Evolve 18 bhp chip with k&n panel filter
M42B21 - tim_s 198.3 BHP 172.9 lbft
M47 crank
custom rods and forged JE pistons
fully lightened and balanced
late spec cyl head with +2mm valve throats, 3 angled seats, skimmed 0.2mm to give even higher CR
259/10.4 catcams
megasquirt 2 extra
Custom MLS HG, total seal rings, ARP rod bolts
serpentine belt, coil on plug
M50
M50B25 - Monkey 217.3 BHP 200 lbft
ECU chip by EAT
M30 air box
M50B25 Turbo - craigieeb 452.3 BHP 445.5 lbft
It's a standard 2.5 M50
ARP studs
MLS Gasket
440cc injectors
Borg Warner Turbo
External Tial wastegate
VEMS ecu
running 1.3 bar of boost (controlled By GReddy PRofec B-spec II boost controller)
M52
M52B28 - DanThe 206.8 BHP 196.9 lbft
M50 Inlet Manifold
M52B30 - DanThe 234.1 BHP 239 lbft
M52 steel liner block
E46 330i crank gear
M50 Inlet Manifold
S14
S14B24 Turbo - teamalsoran 490.3 BHP 439.9 lbft
2.4litre s14 turbo
2.3 215bhp top end
Custom pistons
T38 turbo on low boost
Huge intercooler
- spikes in graph low down was a gearchange*
S14B26 - teamalsoran 240.7 BHP 207.2 lbft
-*Upper Graph*-
2.6 litre 275bhp S14
95.34mm Wosner pistons
11.5:1 CR
91mm stroke steel crank
Ported head
Schrick 292/284 cams
S50
S50B30 - billgatese30 293.5 BHP 248.5 lbft
Standard.
Run 1 -
Run 2-
