M20
M20B25 2.5 litre 12 Valve Engine
The M20 is an straight-6 piston engine of BMW.
The 12-valve, belt driven SOHC design was introduced in the 1977 BMW 520/6 and 320/6. With displacements ranging from 2.0 to 2.7 liters, it was the "little brother" to the larger BMW M30 engine. It was intended to replace the larger displacement 4-cylinder motors and was born out of BMW's conviction that a small six had more development potential than a large four (i.e. 2 liters+)
Powering the E21 and E30 3-Series, as well as E12, E28 and E34 5 Series cars, it was produced for nearly two decades, with the last examples powering the E30 325i touring built until sometime in 1993. By that time, the newer twin-cam M50 engines with 4 valves per cylinder had already been used in the E36 and E34 for a couple of years.
Three different head castings were used over the engine's production run. The earliest was #1264200 aka the "200". These were used in all e21 320/6 and 323i and e12 520/6 engines and later in the e28 and e30 eta engines (eta = "Power With Economy"). The next version was #1277731 aka the "731". This head was the same as the 200 but featured larger intake ports. The final version was #1705885 or "885" introduced in the 325i. Ports were further enlarged, valves were larger and the combustion chamber was redesigned to improve flow and thermodynamic efficiency.
Engine Specs
Other variations
- M20b20
- M20b23
