EWS
Revision as of 05:29, 20 March 2012 by Grrrmachine (talk | contribs)
  • ECU
  • EWS module
  • Key
  • Ignition Barrel Ring
  • Send/Receive module (under the steering column)
  • Loom
The ECU, EWSII and key come as a set. If you have the key and EWSII box, they can be reprogrammed to suit a different ECU by someone with the right equipment. So it is best to ensure you get all 3 components from the same car when purchasing, even see if there are spare keys to be had.
M50
M52
Disabling
If you really don't want the hassle of the EWS system, it is possible to deactivate it. This technique only works for the 413 silver label EWS (as fitted to the E36).
The technique involves cutting one wire that leads to the ECU. Therefore, you will need to unclip the plug from the ECU and undo the small screw that holds the plug cover over the wires. With this removed, you will have the wiring exposed like this:
When looking at the wires, identify the very small numbers on the harness (circled in yellow) and find wire 56 at one end of the plug. Count over to the 66th wire, which should be a green wire but is sometimes black and purple. Cut this wire cleanly with wire cutters, then reassemble the plug and reconnect to the ECU.
Reference
Learn more about the EWS system
