Electrical
Engine
Ignition
In this article, Ignition refers to turning the key to make the engine start. For other meanings of ignition, refer to the Ignition page.
Most of your car's electrical systems will activate when the key is put into the ignition barrel and turned. This simple switch clips onto the back of the lock barrel, and goes to a plastic connector that links the switch to the main Loom.
The wiring for the switch is relatively simple; so simple, in fact, that if very rarely causes any problems. Seven wires connect to the switch, which are:
- black/yellow - Start wire
- red - permanent 12V in
- green - Ignition circuits
- green/violet - rear demister
- violet - Ancilliaries (wipers/ lights)
- brown - seat belt warn light
- brown/blue - brake fluid warn light
The essential wires are therefore the black/yellow, red, green and violet cables. However, if your car is not starting and you are looking for faults, you can test the starter from the diagnostic plug in the engine bay.
Main article: ECU
The brain of your car, the ECU is in control of engine running. It takes readings from sensors scattered around the engine bay, and adjusts the fueling accordingly. It also governs whether the Ignition and Fuel circuits are powered, by controlling the DME relay.
Charging
Main article: Charging
To keep everything running, your system needs to generate electricity as it's used. To do that your car has an alternator, driven by a belt from the engine. The alternator is directly connected to the main distribution circuit, as well as to the battery to keep that topped and fresh.
Main article: Loom
Interior
Instruments
Main article: Instruments
Sticking your hand out of the window and wiggling it in the slipstream isn't a very accurate way of measuring speed. For that reason, your car is kitted out with all manner of dials, clocks and gauges to keep you informed of how the car is working.
Stereo
Main article: Audio
While the noise of the engine should be all you need when driving an E30, many people want some phat sounds while driving, to while away the motorway miles.
The E30 was available with a wide range of stereo head units from the factory, and all of the wiring is in place to fit four speakers within the cabin. There is also extra wiring provided for tweeter pods, which fit into the front doors.
All of the stereo wiring is a one-piece accessory loom using a standard BMW colour coding system, and isn't really compatible with more modern stereos. Because of that, most cars have had their wiring butchered and chopped over the past two decades by enthusiastic teens and ill-informed installers, so the current state of your stereo system could be a complete mystery.
Exterior
Lights
Main article: Lights
Inside and out, your car is fitted with a multitude of bulbs. While the most obvious is to provide illumination so that you can see what you are doing, the majority of them provide information on the status of your car. Understanding not only the headlights but also the instrument and check panel lights will hep you keep your car in optimum condition.
Windows
Main article: Windows
Wing Mirrors
Main article: Wing Mirrors
Locks
Main article: Central Locking
Sunroof
Main article: Sunroof
While poverty-specification vehicles came with a windy handle to open and close the roof, some buyers opted for the electric alternative. Mounted in the roof and activated with a switch above the driver's head, the motor offered two functions; upward tilt and full recline.
Windscreen Wipers
Rear Demister
Since the E30 is such a superior vehicle, you'll be using your rear view mirror a lot to watch the losers you left behind at those traffic lights. But in cold and damp conditions, the rear window can steam up, obscuring your view and spoiling your moment of victory. For that purpose, all E30s are fitted with a rear demister (or defogger, if you're American), to help keep the glass clear.
The demister is made up of simple carbon strips stuck to the glass, which warm up when power is passed through them. This wire lattice is powered by its own circuit, and is activated by a switch on the dashboard.
Cruise Control
Main article: Cruise Control
Heated
The term Heated can be applied to a number of accessories on the E30. The list of heated features includes:
The main Loom provides plugs for all of these accessories in their respective locations, but there are no switches; all heated components except the Seats are activated automatically when the ignition is turned on.
If you feel the need to prepare your car for cold weather climes, then learn more about retrofitting heated washer jets.
Central locking: It is very common for E30s to develop issues with their central locking. This is caused by a constant live power source running through the door which, over time, causes the terminals in the door loom to corrode. This has a simple fix which all E30s can benefit from.
