CID
Cylinder Identification (CID)
An cylinder identification sensor is used to identify cylinder firing sequence. The sensor is connected around the HT lead of cylinder number 4 (4 cylinder) or cylinder number 6 (6 cylinder) adjacent to the distributor. As the HT pulses travel along the HT lead, a small AC signal is induced in the sensor and returned to the ECU. The ECU utilises an ADC to transform the signal into a digital pulse.
The Motronic ECU contains a fuel map with an injector opening time for basic conditions of speed and load. Information is then gathered from engine sensors such as the AFM, CAS, CTS, and TS. As a result of this information, the ECU will look-up the correct injector pulse duration right across the engine rpm, load and temperature range.
The injectors are arranged in two banks with injectors 1 and 3 (4 cylinder) or 1, 3 and 5 (6 cylinder comprising one bank, and injectors 2 and 4 (4 cylinder) or 2, 4 and 6 (6 cylinder) making up the other bank. Each bank is connected to the ECU via an independent ECU pin.
During start-up from cold, injector pulse duration is increased to provide a richer air/fuel mixture and pulse frequency is also increased. In addition, the ignition timing is also retarded. Injector frequency & pulse duration and degree of timing retard depend upon the engine temperature both during start-up and immediately afterwards. If the engine is restarted within one minute of the first start occurance, less overall fuel is injected to reduce the risk of fuel flooding into the engine.
