BMW Dealership Maintenance - Inspection 1
Revision as of 20:56, 5 October 2011 by Grrrmachine (talk | contribs)
INSPECTION 1
Engine Compartment
  • Check and adjust valve clearance (M20)
  • Change oil and oil filter.
  • Check battery acid level and correct if needed.
  • Check coolant level and inspect system for leaks.
  • Check steering fluid and brake/clutch fluid level.
  • Check windshield washer fluid level.
  • Check ATF fluid and LAD level (if equipped).
  • Lubricate throttle linkage
Undercarriage
  • Check transmission for external leaks.
  • Check manual transmission level, add if needed.
  • Check final drive fluid level, add if needed.
  • Check fuel lines, fuel tank and all connections for leaks.
  • Inspect exhaust system.
  • Check steering box and steering linkages for leaks and excess play.
  • Inspect brake callipers, discs and brake pad thickness.
  • Inspect brake hoses and lines for damage or leaks.
  • Check handbrake, adjust cable if needed.
  • Inspect front suspension and wheel bearings for play.
  • Inspect wheels, tyres and adjust tyre pressures.
  • Check spare tyre pressure.
Body and Interior
  • Lubricate door hinges, bonnet latch and bonnet hinges.
  • Check operation of exterior/interior lights (including glove box, engine compartment… ).
  • Check headlight aiming.
  • Check condition and function of seat belts.
  • Check operation of washer system.
  • Check wiper blades condition.
  • Check active check control panel for faults.
  • Check function of air conditioning. Check refrigerant charge at sight glass.
  • Tighten A/C compressor mounting bolts.
  • Tighten nuts and bolts for door locks and striker plates.
  • Replace intake dust/pollen micro filter in A/C unit.
  • Replace batteries for alarm/remote control in master key (if equipped).
Road Test
