Revision as of 20:07, 28 September 2011 by Grrrmachine (talk | contribs)
Basic checks
What can be improved?
Brake "power"
Unsprung mass,
Rotational mass
Fade (pad) resistance
Fade (fluid) resistance
Heat reduction
Disc "warping" resistance
E30 brake upgrade options
- The WMS 280mm (fits 15" BBS & 16" Alpina) and 298.5mm (fits 16" Hartge & AC Schnitzer) 4-pot kits which have custom 1.25" E30-specific pistons.[1]
- 302mm disks with 4 pot callipers can be made to fit under 16" wheels - Baddave's current set-up which apparently works rather well.
- <<please update me>>
  • Volkswagen Corrado G60 280mm. Centrebore must be enlarged 1mm to fit E30 hub. Can be fitted with Mazda RX7 callipers
<<Please update me>>
  • Bmw E30M3
  • Bmw E32 750i
Cars with 4pot callipers
  • Aston Martin(various)-DB7
  • Alfa Romeo GTV/166
  • Audi Possibly RS2,S8,RS8
  • BMW E38 730i, 735i
  • BMW E31 840i,850i,850csi
  • Ferrari (all newer models)
  • Fiat Coupe
  • Ford Focus RS
  • Ford Sierra RS Cosworth 3dr
  • Jaguar S type R
  • Lancia Delta(integrale)
  • Lancia Phedra
  • Mazda RX-7
  • Mitsibishi 3000GT
  • Nissan 300ZX
  • Nissan 350Z
  • Peugeot 607(possibly)
  • Peugeot 807(possibly)
  • Peugeot 406 Coupe
  • MG MGF
  • Seat Cupra R (Ibiza,Leon)
  • Subaru Impeza STI
  • Toyota Hilux
  • Toyota Celica GT4
  • Toyota Supra
  • TVR ( certain newer models)
