.Basic checks:
What can be improved?
Brake "power"
Unsprung mass,
Rotational mass
Fade (pad) resistance
Fade (fluid) resistance
Heat reduction
Disc "warping" resistance
- The WMS 280mm (fits 15" BBS & 16" Alpina) and 298.5mm (fits 16" Hartge & AC Schnitzer) 4-pot kits which have custom 1.25" E30-specific pistons.[1]
- 302mm disks with 4 pot callipers can be made to fit under 16" wheels - Baddave's current set-up which apparently works rather well.
- <<please update me>>
<<Please update me>>
- Bmw E30M3
- Bmw E32 750i
Cars with 4pot callipers
- Aston Martin(various)-DB7
- Alfa Romeo GTV/166
- Audi Possibly RS2,S8,RS8
- BMW E38 730i, 735i
- BMW E31 840i,850i,850csi
- Ferrari (all newer models)
- Fiat Coupe
- Ford Focus RS
- Ford Sierra RS Cosworth 3dr
- Jaguar S type R
- Lancia Delta(integrale)
- Lancia Phedra
- Mazda RX-7
- Mitsibishi 3000GT
- Nissan 300ZX
- Nissan 350Z
- Peugeot 607(possibly)
- Peugeot 807(possibly)
- Peugeot 406 Coupe
- MG MGF
- Seat Cupra R (Ibiza,Leon)
- Subaru Impeza STI
- Toyota Hilux
- Toyota Celica GT4
- Toyota Supra
- TVR ( certain newer models)
