Technical
Revision as of 15:55, 22 September 2011 by Grrrmachine (talk | contribs)
E30 Technical
Engine
Saloons
Name Volume Engine Valvetrain Fuel Output Torque Engine code 0–100 km/h,s Top speed Years
316i Template:Convert 4cyl SOHC 8V Petrol 101hp (75kW) @4500 rpm 103ft/lb (140Nm) @4250 rpm M40B16
M43B16
13.1
12.7
Template:Convert
Template:Convert
1990–1993
1993–1998
316i Template:Convert 4cyl SOHC 8V Petrol Template:Convert @5500 rpm
Template:Convert @4250 rpm
Template:Convert @3900 rpm
M40B18
M43B18
11.5
11.3
Template:Convert
Template:Convert
1990–1993
1993–1998
318i Template:Convert
Template:Convert
4cyl DOHC 16V Petrol Template:Convert @6000 rpm Template:Convert @4500 rpm
Template:Convert @4300 rpm
M42B18
M44B19
10.2 Template:Convert 1992–1996
1996–1998
318i Template:Convert 6cyl DOHC 24V Petrol Template:Convert @5900 rpm Template:Convert @4700 rpm
Template:Convert @4200 rpm
M50B20
M52B20
10.0
9.9
Template:Convert 1991–1994
1994–1998
318is Template:Convert 6cyl DOHC 24V Petrol Template:Convert @5500 rpm Template:Convert @3950 rpm M52B25 8.0 Template:Convert 1995–1998
320i Template:Convert 6cyl DOHC 24V Petrol Template:Convert @5900 rpm Template:Convert @4700 rpm
M50B25
M50B25
8.0
7.5
Template:Convert 1991–1993
1993–1995
323i Template:Convert 6cyl DOHC 24V Petrol Template:Convert @5300 rpm Template:Convert @3950 rpm M52B28 6.9 Template:Convert 1995–1998
325i Template:Convert 4cyl SOHC 8V Diesel Template:Convert @4400 rpm Template:Convert @2000 rpm M41D17 14.4 Template:Convert 1994–1998
M3 Template:Convert
Template:Convert
6cyl DOHC s24V Petrol Template:Convert @7000 rpm
Template:Convert @7400 rpm
Template:Convert @3600 rpm
Template:Convert @3250 rpm
S50B30
S50B32
5.4
5.2
Template:Convert 1992–1995
1995–1998
324d Template:Convert 6cyl SOHC 12V Diesel Template:Convert @4800 rpm Template:Convert @1900 rpm
M51D25
M51D25
12.0 Template:Convert 1991–1996
1996–1998
32td Template:Convert 6cyl SOHC 12V Diesel Template:Convert @4800 rpm
Template:Convert @4600 rpm
Template:Convert @2200 rpm
M51D25
M51D25
10.4 Template:Convert 1993–1996
1996–1998
The E30 was available with a number of engines. The M10, the M40 and the M42 are the four-cylinder engines. The M20 is the six-cylinder engine, fitted to the 320 and 325. A rare version of the M30 was fitted to the 333i, available in South Africa, and the M30 remains a popular choice among engine swaps. In mainland Europe, the diesel engine M21 was also fitted. but very few were sold in the UK.
Engine Swaps
M50 and M52
Uploading images and files
To upload you'll need to sign-up. See the top right corner if you haven't already created an account.
Once logged in you will see the toolbox in the left panel has an Upload file link. You can use this to upload images for you pages.
To use an image in a page just use
[[Image:Filename.jpg]]
Please note filenames are also case sensitive.
Formatting
This page details the guidelines for how to edit pages on the zone wiki.
A great list of simple formatting options is on the Wikipedia site here: Wikipedia Cheatsheet
For pages that are incomplete please add the stub template by placing the following text at the start of your article:
{{stub}}
This will ensure that it's easy for users to find and update articles that need updating.
Tables
{| class="wikitable"
|+'''Table Title'''
|'''First Column Header'''
|'''Second Column Header'''
|'''Third Column Header'''
|We
|Love
|E30s
|Old
|Skool
|Cool
This should look like:
Table Title
First Column Header Second Column Header Third Column Header
We Love E30s
Old Skool Cool
