Megasquirting Your M20
This Page Is a work in Progress by Gruelius. I am not responsible for any incorrect information (feel free to update it).
Possible Combinations
Motronic 1.3 to Megasquirt
Parts Required
MS2 Extra firmware.
idle driver board.
Wasted Spark
Making the adapter
Main Relay Triggering
Idle Control Valve
Wasted Spark
| Output | V2.2 Input | V3 Input | V3.57 Input |
| Spark A | Right of R25 | Top of R26 | U1 pin 7 |
| Spark B | Right of R28 | Top of R29 | U1 pin 8 |
| Spark C | Right of R26 | Top of R27 | U1 pin 9 |
Oxygen Sensor
image by goathumper from http://www.e30tech.com/forum/showthread.php?t=50206&highlight=lc1+install+stock+harnesse
Tacho Output
Tuning
Software
I highly recommend purchasing TunerStudio. While it is $50 and most e30 owners are broke tight arses (i am guilty of this), spending $50 to be able to quickly dial in your ecu is well worth it. The VE Analyze Live feature has been quite helpful for me as i am not too technically minded. While the free version works perfectly for all intensive purposes, the VE Analyze Live and ignition diagnostic features are fantastic.
ECU Firmware
This guide will assume you are using MS2E 3.1 (Latest release, if it isnt posted on the ms2e website yet go to the support forums to find a download link). 3.1 is now tried and tested and has many benefits over the old 2.1 release.
Before you start
| "MS2 Page, skim over and read sections on functions you are not sure of" | "MS2E Page, Read ALL sections relevant to your install" |
| [5] | [6] |
Settings
Some settings can be copied over but for most of them it is best to enter and calculate them yourselves.
LJET to Megasquirt
Overview & Warning
I have not attempted this so this is just based on available information. This is extremely simple as the ignition is still done by the dizzy so all you need to do is run the injectors
