Megasquirting Your M20
This Page Is a work in Progress by Gruelius. I am not responsible for any incorrect information (feel free to update it).
Possible Combinations
Motronic 1.3 to Megasquirt
Parts Required
MS2 Extra firmware.
idle driver board.
Wasted Spark
Making the adapter
From [1] run by chris325ix
(While that guide is correct, I would and did wire the cps ground to #2, the megamanual hints towards it being a seperate ground in future revisions of MS)
Main Relay Triggering
Idle Control Valve
Wasted Spark
| Output | V2.2 Input | V3 Input | V3.57 Input |
| Spark A | Right of R25 | Top of R26 | U1 pin 7 |
| Spark B | Right of R28 | Top of R29 | U1 pin 8 |
| Spark C | Right of R26 | Top of R27 | U1 pin 9 |
Oxygen Sensor
The LC1 can be wired into the stock harness. I did not take pictures but i just cut the connector off a bosch narrowband and used that. The example i had had four wires, to whites a grey and a black.
The wiring i was told was Grey = Earth, Black = signal, White = Power. I cannot confirm this yet as the ecu has not been run with this lc1 setup yet.
Tacho Output
Apparently the stock level output can run this, if it doesnt work just add a transistor.
Settings
This is best done by looking at the website [www.megamanual.com] and other popular tunes. It is quite simple, just make sure when doing wasted spark you have the right outputs selected. For the trigger wheel the settings are 60 teeth 2 missing and use 84 degrees as your tooth #1 angle.
