Megasquirting Your M20
Revision as of 19:59, 3 February 2011 by Gruelius (talk | contribs)
This Page Is a work in Progress by Gruelius. I am not responsible for any incorrect information (feel free to update it).
Ignore the buggered AFR IAT and CLT values, they werent connected :P
Possible Combinations
Motronic 1.3 to Megasquirt
Parts Required
MS2 Extra firmware.
idle driver board.
Wasted Spark
Making the adapter
This is a photo of how i made my adapter (showing coil boards too) Adaptercase.jpg
From [1] run by chris325ix (While that guide is correct, I would and did wire the cps ground to #2, the megamanual hints towards it being a seperate ground in future revisions of MS) 2dhs0fn.png
Main Relay Triggering
Idle Control Valve
Wasted Spark
Wiring table for wasted spark
Output V2.2 Input V3 Input V3.57 Input
Spark A Right of R25 Top of R26 U1 pin 7
Spark B Right of R28 Top of R29 U1 pin 8
Spark C Right of R26 Top of R27 U1 pin 9
Using the GM V6 Coilpack the internal electronics are to be gutted as we will just be using it for its coils and the coil holder Gmgutted.jpg
Oxygen Sensor
The LC1 can be wired into the stock harness. I did not take pictures but i just cut the connector off a bosch narrowband and used that. The example i had had four wires, to whites a grey and a black.
The wiring i was told was Grey = Earth, Black = signal, White = Power. I cannot confirm this yet as the ecu has not been run with this lc1 setup yet.
Settings
This is best done by looking at the website [www.megamanual.com] and other popular tunes. It is quite simple, just make sure when doing wasted spark you have the right outputs selected. For the trigger wheel the settings are 60 teeth 2 missing and use 84 degrees as your tooth #1 angle.
