Megasquirting Your M20
Revision as of 19:39, 3 February 2011 by Gruelius (talk | contribs)
This Page Is a work in Progress by Gruelius.
Ignore the buggered AFR IAT and CLT values, they werent connected :P
Possible Combinations
Fuel Only (Possible on Ljet cars without any modification as dizzy handles ignition, works with ANY MS ecu) Fuel + Single coil spark (Requires Full Motronic 1.3 conversion for Ljet/Motronic cars) Fuel + Wasted spark (requires motronic 1.3 harness and triggerwheel on ljet cars)
Motronic 1.3 to Megasquirt
Parts Required
MS II ecu (While MS1 can run ignition with megasquirt Extra this guide is for ms2 extra). MS2 Extra firmware M50 TPS and adapter (while not required, very helpful for tuning) LC-1 wideband (i would consider essential but a narrowband could be used, would need a external wideband for tuning) idle driver board
Wasted Spark
coil driver board (before purchasing another board please read the wasted spark section)
Making the adapter
From [1] run by chris325ix (While that guide is correct, I would and did wire the cps ground to #2, the megamanual hints towards it being a seperate ground in future revisions of MS) File:Http://i52.tinypic.com/2dhs0fn.png
Main Relay Triggering
Idle Control Valve
Wasted Spark
Wiring table for wasted spark
Output V2.2 Input V3 Input V3.57 Input
Spark A Right of R25 Top of R26 U1 pin 7
Spark B Right of R28 Top of R29 U1 pin 8
Spark C Right of R26 Top of R27 U1 pin 9
Using the GM V6 Coilpack the internal electronics are to be gutted as we will just be using it for its coils and the coil holder Gmgutted.jpg
