Z3 short shifter conversion
Revision as of 13:21, 6 January 2009 by Hoshy (talk | contribs)
Introduction
Fitting opening rear ¼ windows turned out to be a fairly easy job!
Takes approx 1/2hour per side
You will need to source 2nd hand window assemblies, make sure you get the window/body seals too, if your removing them from a wrecked car yourself see if you can also get hold of the body nuts that the closure mechanism screws to on the C pillar. (BMW part number 07.12.9.925.735 Qty 4 off)
Parts Required
PLEASE NOTE: The Gear Lever is now part number - 25117527252
