Z3 short shifter conversion
Introduction
Fitting opening rear ¼ windows turned out to be a fairly easy job!
Takes approx 1/2hour per side
You will need to source 2nd hand window assemblies, make sure you get the window/body seals too, if your removing them from a wrecked car yourself see if you can also get hold of the body nuts that the closure mechanism screws to on the C pillar. (BMW part number 07.12.9.925.735 Qty 4 off)
Tools needed
8mm socket, long reach advisable
Philips screwdriver
Flat blade screwdriver
Size 11 pair of boots!
1. Locate and remove covers over window fixings, bottom one pulls straight off easily
Parts Required
PLEASE NOTE: The Gear Lever is now part number - 25117527252
