Motronic
The Bosch digital Motronic ECU replaced the older analogue L-Jetronic system.
Contents Motronic ML1.X Motronic 1.1 & 1.3 See also References External links
Motronic ML1.X
Main System Characteristics Fuel delivery, ignition timing, and dwell angle are incorporated into the same ECU to create a 3-dimensional map of the engine parameters relating to engine speed and load. Crank position and engine speed is determined by a pair of sensors reading from the flywheel. Separate constant idle speed system monitors and regulates base idle speed settings. 5th injector is used to provide extra fuel enrichment during different cold-start conditions. Depending on application and version, an oxygen sensor may be fitted (the system was originally designed for leaded fuel). No knock sensor.
Motronic 1.1 & 1.3
Chipping
The Motronic system can be 'chipped', which involves replacing the standard EPROM (Erasable Programmable Read Only Memory) chip with one containing a performance enhancing program or 'map' for improved driveability, throttle response, mpg, raised rev limit, etc. Alternatively, the existing EPROM can be blanked in an ultra-violet EPROM eraser and a new program burned into it using an EPROM programmer linked to a PC. This is referred to as a remap, commonly carried out while dyno testing for optimising the fuelling, etc.
The EPROM in a 320i or 325i is a 27C256 type, a 28-pin DIL (Dual In-line) chip. It contains 256K-bits of CMOS memory (arranged as 32,000 words x 8-bits).
Hexadecimal Language: 85 0A F0 30 F0 51 D5 08 4E E5 09 B4 00 24 43 C1 C0 C2 AF C2 93 F5 C6 D2 AF 53 C1 3F 74 F4 25 C6 F5 C6 74 01 35 C7 F5 C7 43 C1 80 D2 93 75 08 0A 80 67 B4 01 24 43 C1 30 C2 AF C2 92 F5 C4 D2 AF 53 C1 CF 74 F4 25 C4 F5 C4
Motronic ECU Codes
316i: 0 261 200 174/989
318is: 0 261 200 175
M3 2.3: 0 261 200 071
M3 2.5: 0 261 200 091
535/635/735i M30B35 uses 0 261 200 150 (Motronic 1.1) (24-pin EPROM) 0 261 200 179 (Motronic 1.3) (28-pin EPROM) Note: These are compatible plug & play replacement ECUs!
References
^ [2]http://www.ludd.luth.se/~rotax/motronic/motronic.html
^ [3]http://frwilk.com/944dme/
^ a b c [4]http://www.opel-scanner.com/files/Opel_MotronicML4.1.pdf
^ a b c [5]http://www.taylor-eng.com/ecu/motronic_intro.html
^ [8]http://www.opel-scanner.com/files/DME_1.1_1.3.pdf
