Motronic
Revision as of 18:45, 30 December 2008 by 91.111.127.108 (talk)
Bosch Motronic ECU
The Bosch digital Motronic ECU replaced the older analogue L-Jetronic system. From Wikipedia, the free encyclopedia
Motronic 4.1 The Motronic 4.1 system was used on Opel/Vauxhall 8-valve engines from 1987-1990[4], and some PSA Peugeot Citroën XU9J-series engines[5].
The Motronic system can be 'chipped', which involves replacing the standard EPROM (Erasable Programmable Read Only Memory) chip with one containing a performance enhancing program or 'map' for improved driveability, throttle response, mpg, raised rev limit, etc. Alternatively, the existing EPROM can be blanked in an ultra-violet EPROM eraser and a new program burned into it using an EPROM programmer linked to a PC.
Hexadecimal Language: 85 0A F0 30 F0 51 D5 08 4E E5 09 B4 00 24 43 C1 C0 C2 AF C2 93 F5 C6 D2 AF 53 C1 3F 74 F4 25 C6 F5 C6 74 01 35 C7 F5 C7 43 C1 80 D2 93 75 08 0A 80 67 B4 01 24 43 C1 30 C2 AF C2 92 F5 C4 D2 AF 53 C1 CF 74 F4 25 C4 F5 C4
The EPROM in a 320i or 325i is a 27C256 type, a 28-pin DIL (Dual In-line) chip. It contains 256K of CMOS memory (arranged as 32K x 8-bits).
