Talk:325iS South African Model
Revision as of 09:37, 25 August 2008 by 212.183.134.129 (talk)
Hi Braaicharcoal speaking from Cape Town.
What you say of 325iS model in SA is not quite correct. It is substantially different from normal 325i. It was not simply a body kit.
Engine was 2.8 with different management system. Wheels were 5 stud 15 inch. Gear ratios were entirely different along with back axle ratio. Doors boot and bonnet were alloy giving a significant weight reduction.
All in all it did have a fairly higher performance than the 325i
Regards
Hi,
Cool - then please update the article - you can do it yourself :)
Then let's get the Savannahs and boerewors in and have ourselves a lekker braai :)
Hoshy
