Advanced Cleaning Guide
Revision as of 16:56, 22 July 2008 by March109 (talk | contribs)
Introduction
Products Required
  • Bucket 1 (Essential!)
  • Grit Gaurd (recomended if your only using one bucket)
  • Hose/powerhose/Clean water source. (One of is Essential!)
  • Lambs wool wash mit (Essential!)
  • Zaino Shampoo (or similar shampoo, Essential)
  • Zaino aio AND/OR ZFX (aio recomended, one of Essential)
  • Zaino show car polish
  • Drying Towel
  • 2 x Polish applicators
  • 100% cotton terry cloth or other for buffing.
Products Optional
  • Bucket 2 (Optional)
  • Meguirs Bug and Tar Remover
  • Zaino clay bar
  • Zaino CS (optional)
  • Porter Cable/Orbital Buffer and accersories
  • Varios buffers applicators and cloths
  • Power hose, snowfoam lance and snow foam
  • Meguirs Wheel Cleener - for regular wheels (do not use on proper polished surfaces)
  • Meguirs/AutoGlym/Autosol metal polish (for you chromy deviants and proper polishing)
  • Poorboys wheel sealent (not essential but two coats of thisand your next wash will be a piece of cake)
Methodical Process and Order
Process Basic Wash Wash and Protect Intensive clean and protect Advanced
Snow Foam N/A N/A N/A X
Rinse X X X X
Wash X X X X
Rinse X X X X
Dry X X X X
Clay N/A N/A X X
Porter Cable/Orbital N/A N/A N/A X
Panel Wipe N/A N/A X X
Z-aio/ZFX X X X X
Buff X X X X
Panel Wipe N/A X X X
Zaino Show Car Polish N/A X X X
Buff N/A X X X
Zaino CS N/A X X X
Washing
Snow Foam
Clay
Panel Wipe
Z-aio / ZFX
  • Z-aio - Zaino polish
  • Z-aio - ZFX'd Zaino polish + Multiple ZFX'd Zaino polish applications
  • ZFX'd Zaino polish + Multiple ZFX'd Zaino polish applications
Zaino CS
Why Don't I use a Sponge?
The Two Bucket Bufty Method
--March109 16:56, 22 July 2008 (UTC)
