M40 Timing Belt Change
Revision as of 05:31, 23 August 2010 by Willnz (talk | contribs) (Protected "M40 Timing Belt Change" [edit=sysop:move=sysop] [cascading])
M40 Timing Belt Change (Originally Submitted on the E30 Zone by Gwynleym10 Please visit OverlandintheSun.com to see his charity drive from London to Cape Town)
Please note that this car had air - con so ignore the extra pipes / slightly bigger radiator + compressor.
Take the fan cowling off:
Pile of bits...
Old belt:
I then changed the rollers and then tensioners this is so obvious how to do it - you undo the bolts! Re-fit a new belt belt:
Starting from the bottom:
Tighten it up:
Fitting is the reverse of removal.....!
