BMW Dealership Maintenance - Inspection 2
Revision as of 20:25, 30 October 2010 by Skipunda (talk | contribs) (Protected "BMW Dealership Maintenance - Inspection 2" [edit=autoconfirmed:move=autoconfirmed])
Please update with service intervals and other relevant information
INSPECTION 2
The inspection two service is all the Inspection 1 items as well as addition belt and fluid changes.
Engine Compartment
  • Check and adjust valve clearance (M20).
  • Replace camshaft timing belt every other Inspection 2 or 50K miles.
  • Inspect V-belt/Poly-ribbed drive condition, check tension (M20).
  • Lubricate throttle linkage.
  • Change Oil and oil filter.
  • Change air filter or clean it if reusable (like K&N).
  • Check battery acid level and correct if needed.
  • Check Coolant level and inspect system for leaks.
  • Check Steering fluid and brake/clutch level.
  • Check windshield washer fluid level.
Undercarriage
  • Change automatic transmission fluid.
  • Change manual transmission oil.
  • Check clutch plate for wear.
  • Check drive axle boots for leaks.
  • Change final drive fluid (’95 change synthetic fluid every other Insp.II).
  • Replace fuel filter.
  • Check fuel lines, fuel tank and all connections for leaks.
  • Inspect exhaust system.
  • Check steering box and steering linkages for leaks and excess play.
  • Inspect brake callipers, discs and brake pad thickness.
  • Inspect brake hoses and lines for damage or leaks.
  • Check handbrake, adjust cable if needed.
  • Check thickness of parking brake linings.
  • Inspect front suspension and wheel bearings for play.
  • Inspect wheels, tyres and adjust tyre pressures.
  • Check spare tyre pressure.
Body and Interior
  • Lubricate door hinges, bonnet latch and bonnet hinges.
  • Check operation of exterior/interior lights (including glove box, engine compartment… ).
  • Check headlight aiming.
  • Check condition and function of seat belts.
  • Check operation of washer system and wiper blade condition.
  • Check active check control panel for faults.
  • Check function of air conditioning. Check refrigerant charge at sight glass.
  • Tighten A/C compressor mounting bolts.
  • Tighten nuts and bolts for door locks and striker plates.
  • Replace intake dust/pollen micro filter in A/C unit.
  • Replace batteries for alarm/remote control in master key (’95 E34).
Road Test
  • Check braking performance, steering, HVAC, transmission and mirrors.
