320 to 325 throttle body conversion
FFHevW <a href="http://yrwhuqpdmmwo.com/">yrwhuqpdmmwo</a>, [url=http://ncmzismhwyib.com/]ncmzismhwyib[/url], [link=http://qgzqrmpbamwi.com/]qgzqrmpbamwi[/link], http://sauirwvigupa.com/
http://tramadol911.com tramadol 0598 http://edpillsonline.net cialis xieqk http://viagracomparisons.com/ purchase viagra 4121
http://www.tramadol-pills-online.com buy tramadol without priscription xjoxl http://www.36hourpills.com order cialis caktt http://www.good-bye-anxiety.com/ xanax bars >:PPP http://www.buyxanaxnow.net/ xanax 433
http://www.tramadol-pills-online.com tramadol 7603 http://www.meridiapills.com/ meridia buy without perscription wewn http://www.36hourpills.com cialis =-O http://www.phentermineguide.net/ what is phentermine =(( http://www.buyxanaxnow.net/ order xanax eivix
http://www.orderlevitrapills.com/ levitra 469433 http://www.36hourpills.com/ online store cialis :-PP http://www.prozacsearch.com/ prozac 746 http://www.phentermine-hcl.org/ phentermine zymef
Refitting
1. Use a cable tie to compress the spring that fits around the crankcase breather tube, fit the spring to the tube and fit the tube into the crankcase.
2. Using new gaskets fit the inlet manifold onto the cylinder head.
3. Refit the inlet manifold mounting nuts and torque to17 Lbft.
4. Using a sharp knife or wire cutters cut the cable ties on the crankcase breather tube spring and locate the top of the tube into the recess on the underside of the inlet manifold.
5. Refit and connect the injector loom multi plug.
6. Refit the blue and brown temperature sensor plugs
7. Using a new gasket fit the throttle body onto the manifold and tighten the mounting nuts.
8. Refit the pipes to the throttle body.
9. Refit the throttle switch connector.
10. Refit the fuel supply and return pipes
11. Fit the idle control valve and the induction tube.
12. Fit the airflow meter and air filter box.
13. Fit the throttle cable and adjust as necessary.
14. Refit the inlet manifold support bracket.
15. Double check that everything is tightened and connected.
16. Refit the battery.
Be aware that removing and re-connecting the battery resets the ECU and upon starting the car the ECU must retune itself, therefore the idle speed may be a little erratic for a while.
This article is copy write to E30zone and must not be replicated without prior permission. Written and photographed by Iain Temple (Templ8e30)
