Z3 short shifter conversion
Revision as of 21:19, 12 February 2013 by Grrrmachine (talk | contribs)
Choice of Rod
A number of gear levers are available from the Z-range of cars to change the feel of your gearstick, shown below.
The important thing to look for is the space between the ball joint (in the line) and the selector rod joint (far right). The longer the distance, the shorter the shift.
As you can see, there are a number of options available, but not all of them are practical. The Z3 2.8 lever gives a very switchy feel to the gearstick, with very little needed to shift from 1st to 2nd gear. The Z3-M is the shortest of them all, to the point of putting your synchromesh gears at risk; for that reason we do not recommend the use of this lever.
Parts
Description Part Number Price (£) Quantity Total Price (£)
Recondition Parts Gear selector rod joint 25 11 7 501 309 14.39 1 14.39
Dowel pin 23 41 1 466 134 0.29 1 0.29
O ring 25 11 1 221 243 0.31 2 0.62
Spacer ring 25 11 1 220 199 0.12 1 0.12
Circlip 07 11 9 932 863 0.12 1 0.12
Short Shift Parts Gear lever 25 11 7 527 252 36.46 1 36.46
Spacer ring 24 11 1 220 439 0.30 2 0.60
Circlip 25 11 7 571 899 0.37 2 0.74
Shift lever bearing 25 11 1 220 600 6.08 1 6.08
New gasket Exhaust gasket 18 30 1 711 969 7.96 1 7.96
Total 67.38
Variations
For pre-facelift cars, you may find your carrier is different to the one above.
In terms of console bushings, there are three. In the diagram above, they are parts 1 and 7. It's also worth getting a couple of 2's, as they come with locking material on them (and are known to back out of the transmission). It can't hurt to get a couple 8's and 9's either, as they are easy to lose and the clips are easy to break. For a proper job, 14 is a rubber washer that wears out over time.
Number Part Number Quantity
1 25 11 1 208 580 2
2 25 11 1 205 659 2
7 25 11 1 204 422 1
8 25 11 1 209 078 4
9 25 11 1 220 379 2
14 23 41 1 466 118 1
For the shift lever, you really don't need any parts. You can reuse ones off of your old shifter, but you have to grind down the metal ball and it's a real chore. Considering how cheap the parts are, it's better just to get new ones. Here's the list for stuff to replace in the two pics above:
Upper Diagram: 4: 25 11 1 207 744 (1) 8: 23 41 1 200 844(1) 12: 23 41 1 466 112 (1) Lower Diagram: 4: 23 41 1 466 110 (1)
For installation, you're going to have to file down the inner rim of the upper ball cup to slide it down over the Z4 lever.
