E30 Dyno Graphs
M10
| Engine | Zoner | Power | Torque | Information | Dyno Graph |
| M10B20 | teamalsoran | 200.2 BHP | 156.7 lbft | 2.0 M10
Ported 121 head 12.1 CR Lester Owen reduced overlap 336 cam 45mm jenveys |
| M10B22 Turbo | teamalsoran | 316.5 BHP | 346.9 lbft | 2.2 litre m10 turbo
Schrick 284 cam T34 turbo |
Lots of lines on above graph, thats high and low boost settings |
| M10B25 | teamalsoran | 240.7 BHP | 207.2 lbft | 2.5 litre m10
custon accratlie pistons in a 2.5 s14 bottom end m10 121 head 12.1CR schrick 336 cam 50mm jenvey throttle bodies |
-*Lower Graph*- |
M20
M20B25
| M20B25 | bss325i | 185.7 BHP | 196 lbft |
'89 325i Sport with low compression ration 8.8:1 M20B25. Before and after BTB2 manifold, no other mods. |
| M20B25 | Simon | 183.7 BHP | 191 lbft |
Redline - Standard Purple Line - Hottuning exhaust manifold, no fueling adjustments made |
| M20B25 | clarko74 | 167.6 BHP | 144 lbft | A-Tech Chip
180k Miles on the engine. |
| M20B25 | Hoobs | 164.5 BHP | 144 lbft | Standard | |
| M20B25 | Hoobs | 170.1 BHP | 136 lbft |
This is after a service & running a 'Speedtouch' wild chip 6 branch of unconfirmed origin |
| M20B25 | gaszman | 163 BHP | 171 lbft | Standard high comp prefacelift engine
M1.0 Motronic |
| M20B25 | MattG | 209 BHP | 235 lbft | Standard m20 2.5
Megasquirt NOS on 91 octain petrol |
| M20B25 | hongkongfuey | 192.1 BHP | 189.9 lbft |
stock 2.5 cam bbtb (home made) hottuning manni (no x pipe) m30 injectors and afm home made intake elbow dmcl chip lightened flywheel |
| M20B25 | nadz325i | 189 BHP | 173.5 lbft | BTB 6 Branch
BBTB ITG Induction Kit Schrick 284/272 CAM |
At the wheels figures. |
|- |M20B25 Turbo |Turbo-Brown |269.9 BHP |240.3 lbft |Early 9.7:1 compression M20B25
Two Skyline turbos
6 throttles
Tubular manifolds
Twin 2" exhausts
Two cossie 2WD ICs |
M20B27
| Alpina C2 2.7 | Simon13 | 198 BHP | 220 lbft | Racing Dynamics 6 branch with full scorpion | |
| M20B27 | Oguz327 | 225.6 BHP | 204.8 lbft | 2.7 M20, fully lightened, balanced and blueprinted built by A Tech
285/285 cat camshaft BTB 6 branch BBTB Rolling road remap ITG filter Full scorpion system M1.3 Motronic + chip |
| M20B27 Megasquirt | Oguz327 | 227.8 BHP | 208.6 lbft | 2.7 M20, fully lightened, balanced and blueprinted built by A Tech
285/285 cat camshaft BTB 6 branch BBTB Rolling road remap ITG filter Full scorpion system Megasquirt for engine management, with AFM delete and wasted spark MAP sensor for load(speed Den) |
| M20B27 | oakey | 205.7 BHP | 224 lbft | 135mm rods
Standard head Bexley Block Megasquirt for engine management, with AFM delete and wasted spark |
| M20B27 ITBs & Megasquirt | oakey | 218.6 BHP | 211.8 lbft | 135mm rods
Alpina pistons ETA crank 11.016:1 CR ITBs 280/280 cat camshaft mild head port Megasquirt for engine management, with AFM delete and wasted spark TPS only (Alpha-N algo) |
| M20B27 | Daimlerman | 178.3 BHP | 191 lbft | 525e Block
731 Head Miller MAF |
| M20B27 | Jimbob | 200.4 BHP | 199 lbft | 525e Crank and Rods
High comp M20B25 pistons 325i block decked Standard 325i head Dbilas 284/272 with standard springs BTB 6 Branch A-Tech Chip |
| M20B27 | DaveD | 189.2 BHP | 192.4 lbft | ETA block
re mapped pipercross intake bbtb magnex 6 branch scorpion bbox |
M20B28
| M20B28 | Bullet_Ride | 182.6 BHP | 193.8 lbft | Schrick 284/272 with stock valve springs.
Block shaved 0.5mm Pistons had valve reliefs cut deeper due to only 0.5mm valve clearance on the intake valve. |
On a hot summer day with the car running rich because of a bad O2 sensor this is what was put down... |
| M20B28 | stonesie | 206 BHP | 203 lbft | B25 low comp pistons, block and head both skimmed (minimal on the head, 0.5mm on the block to retain standard squish) approx 9.7:1 CR
M52B28 crank M20B20 rods CatCams 273/273 with vernier Lightweight flywheel A Tec 2.8 chip tweaked for LPG BBTB Ultrasonicly cleaned B25 injectors Standard exhaust manifold/down pipes, new genuine middle box and a magnex back box |
Graph shows at the wheel figures, flywheel converted figures estimated at 206 bhp and 203Lb:Ft |
| M20B28 | goosiegander | 195.4 BHP | 175.4 lbft | M20 2 ltr block bored to 84.0mm
Single vanos M50B28 crank M20 2 ltr conrods M20 2.5 facelift (low comp) pistons Catcam 285/285 degree camshaft 885 headcasting BBTB Hottuning 6 branch and scorpian system 2.8 Motronic chip |
| M20B28 MAF | goosiegander | 200 BHP | 190.1 lbft | M20 2 ltr block bored to 84.0mm
Single vanos M50B28 crank M20 2 ltr conrods M20 2.5 facelift (low comp) pistons Catcam 285/285 degree camshaft 885 headcasting BBTB Hottuning 6 branch and scorpian system MAF Conversion |
| M20b28 Turbo | Gunni | 400.8 BHP | 465 lbft | M20B28 8:1 compression
60trim TCD T4 turbo log manifold 1.1bar boost |
M20B31
| M20B31 | reggid | 220 BHP | 218 lbft | M20B31 - 3086cc
10.5:1CR BTB2 BBTB standalone catcams 298/285 |
At the wheels figures |
M30
| M30B35 | driftmonkey | 206.5 BHP | 213 lbft | Standard | |
| M30B35 B10 Alpina | driftmonkey | 257 BHP | 285 lbft | Alpina B10
Forged custom mahle pistons (high comp) M5 conrods Flowed head with hemi combustion chambers Larger valves 268 degree cam Remapped ECU |
| M30B35 Turbo | Toby_Unna | 295.6 BHP | 330 lbft | Turbo Conversion
Megasquirt |
| M30B35 | Andy335Touring | 248 BHP | 217 lbft | Cam/head work/chip | |
| M30B35 | gareth | 221 BHP | 238 lbft | Free flowing exhaust
compression increased from 9:1 to 10:1. ignition etc are all unchanged at present. LPG system, single point 37mm mixer, OMVL R90/e vap, leonardo ecu. |
On petrol with mixer venturi removed - 221 bhp, 238 lb.ft
On petrol with mixer venturi fitted - 204 bhp, 223 lb.ft On LPG with mixer venturi fitted - 183 bhp, 216 lb.ft |
M40
M42
| M42B18 | agreen | 147.6 BHP | 136 lbft | Green line: standard
Pink line: with Evolve Automotive chip fitted |
| M42B18 | Magpie | 152 BHP | 135.8 lbft | Evolve 18 bhp chip with k&n panel filter | |
| M42B21 | tim_s | 198.3 BHP | 172.9 lbft | M47 crank
custom rods and forged JE pistons fully lightened and balanced late spec cyl head with +2mm valve throats, 3 angled seats, skimmed 0.2mm to give even higher CR 259/10.4 catcams megasquirt 2 extra Custom MLS HG, total seal rings, ARP rod bolts serpentine belt, coil on plug |
M50
| M50B25 | Monkey | 217.3 BHP | 200 lbft | ECU chip by EAT
M30 air box 2.5" bore single pipe exhaust system |
| M50B25 Turbo | craigieeb | 452.3 BHP | 445.5 lbft | It's a standard 2.5 M50
ARP studs MLS Gasket 440cc injectors Borg Warner Turbo External Tial wastegate VEMS ecu running 1.3 bar of boost (controlled By GReddy PRofec B-spec II boost controller) |
M52
| M52B28 | DanThe | 206.8 BHP | 196.9 lbft | M50 Inlet Manifold | |
| M52B30 | DanThe | 234.1 BHP | 239 lbft | M52 steel liner block
E46 330i crank gear M50 Inlet Manifold |
S14
| S14B25 | maxfields Dad | 268 BHP | 194.4 lbft | Schrick 284 cams
head work c/f airbox dta and other goodies |
|S14B24 Turbo
|teamalsoran
|490.3 BHP
|439.9 lbft
|2.4litre s14 turbo
2.3 215bhp top end
Custom pistons
T38 turbo on low boost
Huge intercooler |*spikes in graph low down was a gearchange*
|- |S14B26 |teamalsoran |276.4 BHP |235.8 lbft |2.6 litre 275bhp S14
95.34mm Wosner pistons
11.5:1 CR
91mm stroke steel crank
Ported head
Schrick 292/284 cams | -*Upper Graph*-
S50
| S30B30 | billgatese30 | 293.5 BHP | 248.5 lbft | Standard.
Run 1 - 240.5bhp @ 6870rpm - at rear wheels 291.2bhp @ 7021rpm - at flywheel 247.0 lbft @ 4891rpm - max tourque
245.1bhp @ 6955rpm - at rear wheels 293.5bhp @ 6955rpm - at flywheel 248.5 lbft @ 4379rpm - max tourque. |
