Aircon
Compressor
The compressor itself does not pump continuously. Instead, it is activated based on the internal pressure of the system and whether or not the Aircon is turned on. That way, the compressor does not sap precious power, and therefore fuel, from the engine when it's not wanted.
Condenser
Fan
Expansion Valve
Receiver Drier
Evaporator
Pipework
Refrigerant
R-134a Kit
The R-134a kit includes a new receiver drier, valves, pressure switch and some O-rings, like so:
Aircon Clutch
Pressure Switch
Installation
Aircon Won't Turn On
