Aircon
Compressor
Condenser
Fan
Expansion Valve
Receiver Drier
Evaporator
Pipework
Refrigerant
R-134a Kit
The R-134a kit includes a new drier, valves, pressure switch and some O-rings, like so:
Aircon Clutch
Pressure Switch
Installation
Aircon Won't Turn On
