Aircon
Air-conditioning was fitted as an optional extra to E30s as early as 1984, and the system remained largely the same throughout the E30 production run. The system is based around a sealed refrigerant gas, just like your fridge at home. I won't explain the science, but as the refrigerant is converted from a gas to a liquid it gains heat; as it goes back to a gas it loses heat and cools, and it is this cooling effect we make use of. It's therefore essential that our system be completely sealed, to keep the refrigerant inside and doing what it should.
Compressor
Condensor
Receiver Drier
Evaporator
Expansion Valve
Pipework
Refrigerant
R-134a Kit
Electric Fan
Aircon Clutch
Pressure Switch
Installation
Aircon Won't Turn On
