C191
C191 plug and injector wiring
The C191 is a connector on the engine loom. It allows you to disconnect the wiring to the fuel injectors without having to remove the entire loom.
It is located underneath the intake manifold, and is a known water trap. The resulting corrosion of the wires leads to mis-fuelling, either to failure of the injectors or lack of data from the temperature sensor to the ECU.
If your C191 has rotted away, it is acceptable to cut it out and join the two halves of the loom together to cure the problem.
Note: The C191 plug is not to be found on earlier versions of the e30, only on the later "facelift" models with motronic 1.3 ECU.
| Pin | Colour | Circuit | To | Image |
| 1 | Brown/Red | Coolant Temperature Sensor | ECU pin 45 |
| 2 | Brown/Orange | Coolant Temperature Sensor | Ground G103 | |
| 3 | Brown or Brown/Yellow | Coolant Temperature Sender | Ground G200 | |
| 4 | Brown/Violet | Coolant Temperature Sender | ||
| 5 | Red/White | Fuel Injectors | DME relay | |
| 6 | Brown/White | Fuel Injectors 1, 3, 5 | ECU pin 16 | |
| 7 | Brown/Yellow | Fuel Injectors 2, 4, 6 | ECU pin 17 |
