C191
Revision as of 08:44, 27 January 2012 by Grrrmachine (talk | contribs)
C191 plug and injector wiring
The C191 is a connector on the engine Loom. It allows you to disconnect the wiring to the fuel injectors without having to remove the entire loom.
It is located underneath the intake manifold, and is a known water trap. The resulting corrosion of the wires leads to mis-fuelling, either to failure of the injectors or lack of data from the temperature sensor to the ECU.
If your C191 has rotted away, it is acceptable to cut it out and join the two halves of the loom together to cure the problem.
Pin Colour Circuit To Image
1 Brown/Red Coolant Temperature Sensor ECU pin 45 C191.jpg
2 Brown/Orange Coolant Temperature Sensor Ground G103
3 Brown or Brown/Yellow Coolant Temperature Sender Ground G200
4 Brown/Violet Coolant Temperature Sender
5 Red/White Fuel Injectors DME relay
6 Brown/White Fuel Injectors 1, 3, 5 ECU pin 16
7 Brown/Yellow Fuel Injectors 2, 4, 6 ECU pin 17
