Electrical
Engine
Ignition
Main article: ECU
The brain of your car, the ECU is in control of engine running. It takes readings from sensors scattered around the engine bay, and adjusts the fueling accordingly.
Charging
Main article: Charging
To keep everything running, your system needs to generate electricity as it's used. To do that your car has an alternator, driven by a belt from the engine. The alternator is directly connected to the main distribution circuit, as well as to the battery to keep that topped and fresh.
Main article: Loom
Interior
Instruments
Main article: Instruments
Sticking your hand out of the window and wiggling it in the slipstream isn't a very accurate way of measuring speed. For that reason, your car is kitted out with all manner of dials, clocks and gauges to keep you informed of how the car is working.
Stereo
Main article: Audio
While the noise of the engine should be all you need when driving an E30, many people want some phat sounds while driving, to while away the motorway miles.
The E30 was available with a wide range of stereo head units from the factory, and all of the wiring is in place to fit four speakers within the cabin. There is also extra wiring provided for tweeter pods, which fit into the front doors.
All of the stereo wiring is a one-piece accessory loom using a standard BMW colour coding system, and isn't really compatible with more modern stereos. Because of that, most cars have had their wiring butchered and chopped over the past two decades by enthusiastic teens and ill-informed installers, so the current state of your stereo system could be a complete mystery.
Exterior
Lights
Main article: Lights
Windows
Main article: Windows
Wing Mirrors
Main article: Wing Mirrors
Locks
Main article: Central Locking
Sunroof
Main article: Sunroof
While poverty-specification vehicles came with a windy handle to open and close the roof, some buyers opted for the electric alternative. Mounted in the roof and activated with a switch above the driver's head, the motor offered two functions; upward tilt and full recline.
Windscreen Wipers
Rear Demister
Cruise Control
Main article: Cruise Control
Heated
The term Heated can be applied to a number of accessories on the E30. The list of heated features includes:
The main Loom provides plugs for all of these accessories in their respective locations, but there are no switches; all heated components except the Seats are activated automatically when the ignition is turned on.
If you feel the need to prepare your car for cold weather climes, then learn more about retrofitting heated washer jets.
Central locking: It is very common for E30s to develop issues with their central locking. This is caused by a constant live power source running through the door which, over time, causes the terminals in the door loom to corrode. This has a simple fix which all E30s can benefit from.
