On-board Computer
The On Board Computer (OBC) was a digital meter unit offered by BMW. It provided live data such as time, average speed and fuel range, and was mounted in the centre console.
Types
6-button
13-button
The 13 button OBC was optional on 6 cylinder cars in the UK, and standard on all SE models. They continue to be an extremely desirable extra, and are a popular retrofit due to their larger range of features compared to the 6-button unit. Learn more about installing the OBC.
Parts
Functions
- Time
- Date
- Outside temperature
- Memo (hourly alarm)
- Average Speed
- Consumption
- User selectable speed limit
- Remaining range on fuel
- Stopwatch timer (for measuring those 0-60 times)
- Code function
HR-DATE
AVG MPH
M MPH
AVG MPG
RANGE
TIMER
TEMP
CODE
SET-RES
REMAINING FUEL
Setting Units
Inaccurate Fuel Range
The range function can be wildly optimistic at times, and needs to be recalibrated to give more realistic readings. To do this, brim the fuel tank and then remove the plastic grommet from the bottom left of the obc. Press the 1000 and 1 buttons at the same time to give a reading of how much fuel is in the tank and then turn the screw behind the grommet until it reads whatever capacity your tank is when full.
AAAA/PPPP
Faulty Bulb
After twenty years, it should be no surprise that the bulb that illuminates the OBC could blow, and require replacing. Unfortunately, on the OBC the bulb is soldered to a circuit board, and BMW replacement prices are constantly rising.
However, it is possible to de-solder the bulb from its circuit board, and replace it with a standard 5V unit.
