Fuse Box
Brianmoore: Everyone should print this page off, and compare it with what's in their fusebox.
| Left High Beam Headlight
Relay K3 |
Right High Beam Headlight
Relay K3 |
Auxilliary Fan 91C
Relay K1 |
Flashing Turn Indicators | Wipe-Wash Headlight Cleaning
Brake Lights
Horn
Relay K2 |
(Auto Box) |
Instruments | Fuel Pump
Fuel Supply Pump |
Relay K4 |
Right Low Beam Headlight
Relay K4 |
Rear Fogs
Relay K4 Off when Headlight beams are selected Relay K9 |
| Seat Heating
Relay K5 |
Sliding Roof
Relay K5 Electric Windows |
Auxiliary Fan 99C
Relay K6 |
Mirror Control
Mirror Heating Relay K7 |
Heater Blower
Air Con Relay K7 |
Hazards | Not in use | Rear Wash-Wipe | Central Locking
Cig Lighter
Left Fog Light
Relay K8 |
Right Fog Light
Relay K8 |
