Windscreen Wiper faults
Potential Cure For Stuttering Windscreen Wipers On Intermittent Setting
Originally Written & Photographed by Peter Laing (PeteE30tourer)
One of the most annoying “features” of my cherished E30 is that the wipers barely manage to stutter across the screen when on the intermittent or single wipe settings, even though they work fine on normal or fast modes. Having read several posts on the E30zone forums from others with the same problems, it’s obvious that this is a common problem. I’d read about a possible cure for this in the responses on the forum, so thought I’d give it a go and take a few photos in the process to share it with others. So, here’s what I did.
Remove air-vent panel
There's a special knack to removing the air vents , so don't go in with the screwdrivers trying to pry them off; you'll just scratch your paintwork and crack the plastic.
The correct way to remove the vents is to slide them straight downwards, compressing the three spring clips at the bottom (as shown below) until the plastic hooks at the top come clear of the metal. Then pull outwards at the top, and lift out.
To replace them, put the bottom edge in place, then push down until the clips at the top of the vent clear the metal, allowing the vent to go in flush, then ensure it slides up a couple of mm into place.
Remove the Wiper Mechanism
First thing you’ll note is that the nut holding on the wiper mechanism isn’t easily accessible, so, get in the car, turn on the ignition and set the wipers wiping, but turn off the ignition as they get to the vertical position, thus stopping them there. The motor/mechanism will now look something like this:
To make life easier later on, mark the position of the mechanism so you can be sure to put it back exactly in the same spot. I used a sharp knife to score a line on the motor mounting bracket parallel to the arm. Remove the single nut from the top of the motor shaft and pry off the mechanism. Move it out of the way.
Disconnect the electrics
There is an in-line connector mounted on the side of the motor bracket – towards the driver’s side – see photo below.
Removing the motor
Inspecting and cleaning the motor
Putting it all back together
