Technical
Engines
- Main article: Engines
| Name | Volume | Engine | Valvetrain | Fuel | Output | Torque | Engine code | Years |
| 316 | 1766cc | 4cyl | SOHC 8V | Petrol | 99hp (66kW) @4500 rpm | 103ft/lb (140Nm) @4250 rpm | M10B18 | 1982–1990 |
| 316i | 1596cc | 4cyl | SOHC 8V | Petrol | 102hp (75kW) @4500 rpm | 105ft/lb (140Nm) @4250 rpm | M40B16 | 1988–1995 |
| 318 | 1766cc | 4cyl | SOHC 8V | Petrol | 104hp (77kW) @4500 rpm | 103ft/lb (140Nm) @4250 rpm | M10B18 | 1982–1990 |
| 318i | 1796cc | 4cyl | SOHC 8V | Petrol | 113hp (85kW) @4500 rpm | 122ft/lb (165Nm) @4250 rpm | M40B18 | 1987–1995 |
| 318iS | 1766cc | 4cyl | SOHC 8V | Petrol | 140hp (104kW) @4500 rpm | 127ft/lb (172Nm) @4250 rpm | M42B18 | 1989–1991 |
| 320i | 1990cc | 6cyl | SOHC 12V | Petrol | 123hp (92kW) @5800 rpm | 125ft/lb (170Nm) @4000 rpm | M20B20 | 1982–1985 |
| 320i | 1990cc | 6cyl | SOHC 12V | Petrol | 127hp (95kW) @6000 rpm | 120ft/lb (164Nm) @4300 rpm | M20B20 | 1985–1991 |
| 320iS | 1990cc | 4cyl | DOHC 16V | Petrol | 192hp (143kW) @6750 rpm | 155ft/lb (210Nm) @4750 rpm | S14 | 1982–1990 |
| 323i | 2316cc | 6cyl | SOHC 12V | Petrol | 139-150hp (104-110kW) @4500 rpm | 0ft/lb (0Nm) @4000 rpm | M20B23 | 1982–19850 |
| 325e | 2693cc | 6cyl | SOHC 12V | Petrol | 127hp (95kW) @4250 rpm | 169ft/lb (230Nm) @3200 rpm | M20B27 | 1982–1990 |
| 325i | 2494cc | 6cyl | SOHC 12V | Petrol | 169hp (125kW) @5800 rpm | 163ft/lb (222Nm) @4300 rpm | M20B25 | 1982–1990 |
| 325iX | 2494cc | 6cyl | SOHC 12V | Petrol | 169hp (125kW) @5800 rpm | 163ft/lb (222Nm) @4300 rpm | M20B25 | 1982–1990 |
| M3 | 2302cc | 4cyl | DOHC 16V | Petrol | 197hp (147kW) @6750 rpm | 176ft/lb (0Nm) @4750 rpm | S14 | 1986–1988 |
| M3 | 2302cc | 4cyl | DOHC 16V | Petrol | 212hp (158kW) @6750 rpm | 170ft/lb (0Nm) @4600 rpm | S14 | 1989–1991 |
| M3 Evolution | 2302cc | 4cyl | DOHC 16V | Petrol | 197hp (147kW) @6750 rpm | 176ft/lb (0Nm) @4750 rpm | S14 | 1987–1987 |
| M3 Evolution II | 2302cc | 4cyl | DOHC 16V | Petrol | 217hp (162kW) @6750 rpm | 181ft/lb (0Nm) @4750 rpm | S14 | 1988–1988 |
| M3 Sport Evolution | 2467cc | 4cyl | DOHC 16V | Petrol | 235hp (175kW) @6750 rpm | 177ft/lb (0Nm) @4750 rpm | S14 | 1990–1990 |
| 324d | 2443cc | 6cyl | SOHC 12V | Diesel | 84hp (63kW) @4600 rpm | 112ft/lb (152Nm) @2400 rpm | M21D24 | 1985–1993 |
| 324td | 2443cc | 6cyl | SOHC 12V | Diesel | 114hp (85kW) @4800 rpm | 162ft/lb (220Nm) @2400 rpm | M21D24 | 1985–1993 |
Maintenance
Engine Swaps
- Main article: Gearbox
- Main article: Differential
- Main article: Brakes
- Main article: Suspension
Steering
- Main article: Steering
Body Styles and Fittings
- Main article: Bodywork
The E30 was offered in a number of body styles. A 2-door and 4-door Saloon, Cabriolet and Touring
Maintenance
Electrical
- Main article: Electrical
The E30 loom is a monstrous labyrinth of wires, all colour-coded, so that you can easily trace exactly which wire does what. All wires inside the cabin are part of a one-piece loom that runs through the bulkhead on the passenger side of UK cars, where they meet the Fuse Box.
Maintenance
Ensuring that all the fuses in your Fuse Box are the correct rating is essential in preventing electrical fires. If you are experiencing blown fuses, DO NOT insert a fuse with a higher rating than that in the diagram.
Tables
{| class="wikitable"
|+'''Table Title'''
|'''First Column Header'''
|'''Second Column Header'''
|'''Third Column Header'''
|We
|Love
|E30s
|Old
|Skool
|Cool
This should look like:
| First Column Header | Second Column Header | Third Column Header |
| We | Love | E30s |
| Old | Skool | Cool |
