Basic M20 Servicing
Revision as of 05:19, 23 September 2011 by Grrrmachine (talk | contribs)
M20 Engine - Basic Servicing
Scared of the Spanner?!
This guide was made for you!
Stay calm and take your time.
Tools and Parts Required
8mm socket (for bleed nipple)
!Oil Change
!Spark Plug Change
Masking tape + pen.
19mm Spark plug tool
Overview of an M20
Coolant Change
RHS=Right Hand Side
Tip: spray the bleed nipple with WD40 the night before you do this
****Disconnect Battery****
1. Loosen off and remove the cap on the header tank (On RHS next to wing). Check the surface of the coolant for an oily film. If there is one the head gasket could be on the way out.
Move the heater temp control to fully cold to prevent air locks in the heater matrix
2. Undo bottom hose from radiator at RHS of the car, let coolant drain (catch it in a bucket and dispose of properly)
3. Undo the 3x 10mm bolts on the thermostat housing (at the front of the engine, in front of the distributor cap) (may need to remove small fuel hose to access one of the top bolts)
4. Remove thermostat, and check its ok (should be closed if cold) If in doubt an new one is £9.99 from GSF/ECP. Bolt housing back together.
5. Insert hose into header tank (next to RHS wing) and flush system until water is running clear.
6. Remove top hose (LHS) from radiator and flush through with hose until clear
7. Replace the thermostat, and reattach all hoses
8. Pour the coolant into the header tank (located on RHS next to wing) SLOWLY and give it time to settle. (should take about 4.5l to get to cold level marker)
9. Set the heaters to full (HOT and no. 4 fan setting, open all vents) and start car.
10. Let car idle for 5-10mins keeping an eye on the temp gauge
11. Open the 8mm bleed nipple (on top of the thermostat housing) and allow air to escape, then close.
12. Repeat bleeding until all air is out and only water comes out when bleed nipple is opened. Top up if required.
13. Get a cup of coffee and relax for 20 mins
Oil Change
3. Remove oil filler cap and let car drain for 10mins.(can check how much is left using the dipstick) Check the cap for ‘mayo’ which could be a sign that oil is mixing with the coolant (not good). It can also be caused by the car doing low mileage or not getting up to temperature properly so don't instantly assume the worst!
Spark plugs
1. Remove the Spark plug leads ONE AT A TIME and (using masking tape + pen) number them 1-6.
6. Start the car and go for a well earned cruise
!This article is copyright to E30zone and must not be replicated without prior permission. Written and photographed by Neil Purdom
