Technical
E30 Technical
Engine
Saloons
The E30 was available with a number of engines. The M10, the M40 and the M42 are the four-cylinder engines. The M20 is the six-cylinder engine, fitted to the 320 and 325. A rare version of the M30 was fitted to the 333i, available in South Africa, and the M30 remains a popular choice among engine swaps. In mainland Europe, the diesel engine M21 was also fitted. but very few were sold in the UK.
Engine Swaps
M50 and M52
Uploading images and files
To upload you'll need to sign-up. See the top right corner if you haven't already created an account.
Once logged in you will see the toolbox in the left panel has an Upload file link. You can use this to upload images for you pages.
To use an image in a page just use
[[Image:Filename.jpg]]
Please note filenames are also case sensitive.
Formatting
This page details the guidelines for how to edit pages on the zone wiki.
A great list of simple formatting options is on the Wikipedia site here: Wikipedia Cheatsheet
For pages that are incomplete please add the stub template by placing the following text at the start of your article:
{{stub}}
This will ensure that it's easy for users to find and update articles that need updating.
Tables
{| class="wikitable"
|+'''Table Title'''
|'''First Column Header'''
|'''Second Column Header'''
|'''Third Column Header'''
|We
|Love
|E30s
|Old
|Skool
|Cool
This should look like:
| First Column Header | Second Column Header | Third Column Header |
| We | Love | E30s |
| Old | Skool | Cool |
