Megasquirting Your M20
Revision as of 16:50, 23 September 2011 by Grrrmachine (talk | contribs)
This Page Is a work in Progress by Gruelius. I am not responsible for any incorrect information (feel free to update it).
Ignore the buggered AFR IAT and CLT values, they werent connected :P
Possible Combinations
Motronic 1.3 to Megasquirt
Parts Required
MS2 Extra firmware.
idle driver board.
Wasted Spark
Making the adapter
This is a photo of how i made my adapter (showing coil boards too) Adaptercase.jpg
Main Relay Triggering
Idle Control Valve
Using the board with the settings given to me by a friend my car started and held idle first turn of the key on a cold start.
Wasted Spark
With Wasted spark you will be using non factory coils. There are two types of coils, ones with logic boards inside them and ones that require ignitors. The coilpack i decided to use was a GM V6 coilpack which are quite cheap and readily available at australian yards.
For wasted spark all that is needed is the extra coil drivers and wiring to them. while it is possible to just use the default sparkA output and the 2 spare outputs of the glensgarage idle board, I ended up using a seperate coil driver board. This was because the ECU i got from DIYautotune by default does not have a transistor installed for the sparkA output. Also it is suggested in the MS2E guide that D14 is used for SparkA not JS10.
Wiring table for wasted spark
Output V2.2 Input V3 Input V3.57 Input
Spark A Right of R25 Top of R26 U1 pin 7
Spark B Right of R28 Top of R29 U1 pin 8
Spark C Right of R26 Top of R27 U1 pin 9
Using the GM V6 Coilpack the internal electronics are to be gutted as we will just be using it for its coils and the coil holder Gmgutted.jpg Gmcoil.jpg
Oxygen Sensor
image by goathumper from http://www.e30tech.com/forum/showthread.php?t=50206&highlight=lc1+install+stock+harnesse O2wiring.jpg
Remember to set the multiplier to gasoline in the lm-1 programmer and to perform a free air calibration. If you are only seeing one bank of cylinders (installed o2 without an x pipe like this), it is suggested to set 1/12th of a second resolution.
    • picture here**
Tacho Output
Tuning
Software
I highly recommend purchasing TunerStudio. While it is $50 and most e30 owners are broke tight arses (i am guilty of this), spending $50 to be able to quickly dial in your ecu is well worth it. The VE Analyze Live feature has been quite helpful for me as I am not too mechanically minded. While the free version works perfectly for all intensive purposes, the VE Analyze Live and ignition diagnostic features are fantastic.
ECU Firmware
This guide will assume you are using MS2E 3.1 (Latest release, if it isnt posted on the ms2e website yet go to the support forums to find a download link). 3.1 is now tried and tested and has many benefits over the old 2.1 release.
Before you start
Links to read before you start!
"MS2 Page, skim over and read sections on functions you are not sure of" [5]
[6] "MS2E Page, Read ALL sections relevant to your install"
Settings
Some settings can be copied over but for most of them it is best to enter and calculate them yourselves. I will only list settings that I feel arent self explanatory.
Basic Setup
Control Algorithm = Speed Density
Squirts Per Engine Cycle = highest value so that idle pulse width is no less than 2.0 ms, if possible, and your Req_Fuel is less than 15-18 milliseconds, but more than 6 milliseconds
Injector Staging = Alternating
Engine Stroke = Four Stroke
Engine Type = Even Fire
More Engine Constants (Secondary Load Parameters)
Secondary Fuel Load = Speed density : This is if you are using the two VE maps to get a resolution of 30x16. If you are only using single maps leave this disabled
Secondary Fuel = additive : Again for two VE maps
Primary Ign Load = Speed Density
Secondary Ign Load = Speed Density : This is again only if using 30x16 resolution over 2 maps
Tach Input/Ignition Options
Spark Mode = Toothed Wheel
Ignition Capture = Rising Edge
Spark Output = Going High (Inverted)
Number Of Coils = Wasted Spark (or single coil if single coil)
Spark A output Pin = D14 (again can be sparkA if using the stock transistor).
Trigger Wheel Settings
Teeth = 60 Missing Teeth = 2 Tooth #1 angle = 84 Wheel Speed = Crank Wheel
LJET to Megasquirt
Overview & Warning
I have not attempted this so this is just based on available information. This is extremely simple as the ignition is still done by the dizzy so all you need to do is run the injectors
Wiring guide
