Megasquirting Your M20
This Page Is a work in Progress by Gruelius.
Possible Combinations
Fuel Only (Possible on Ljet cars without any modification as dizzy handles ignition, works with ANY MS ecu) Fuel + Single coil spark (Requires Full Motronic 1.3 conversion for Ljet/Motronic cars) Fuel + Wasted spark (requires motronic 1.3 harness and triggerwheel on ljet cars)
Motronic 1.3 to Megasquirt
Parts Required
MS II ecu (While MS1 can run ignition with megasquirt Extra this guide is for ms2 extra). MS2 Extra firmware M50 TPS and adapter (while not required, very helpful for tuning) LC-1 wideband (i would consider essential but a narrowband could be used, would need a external wideband for tuning) idle driver board
Wasted Spark
coil driver board (before purchasing another board please read the wasted spark section)
Making the adapter
From [1] run by chris325ix (While that guide is correct, I would and did wire the cps ground to #2, the megamanual hints towards it being a seperate ground in future revisions of MS) File:Http://i52.tinypic.com/2dhs0fn.png
Main Relay Triggering
Idle Control Valve
Wasted Spark
| Output | V2.2 Input | V3 Input | V3.57 Input |
| Spark A | Right of R25 | Top of R26 | U1 pin 7 |
| Spark B | Right of R28 | Top of R29 | U1 pin 8 |
| Spark C | Right of R26 | Top of R27 | U1 pin 9 |
File:Http://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs029.ash2/34795 471295937468 605422468 5849863 46769 n.jpg
