Removing Ignition Lock
Revision as of 16:39, 13 November 2009 by Chris-W (talk | contribs)
Here we have a useful guide which shows us exactly how it's done in 5 easy steps.
Equipment Required
  • 25mm picture hanging nail, approximately 1mm diameter
  • Ignition Key
1. Insert key into ignition
Note the half moon shaped hole underneath the key at the bottom of the silver disc
If you look carefully down the hole you’ll see that the casting under the half-moon disappears from view when ‘position 1’ is selected.
The nail must have a ‘taper’ on the end to drive the release pin in, a flat ended implement will not work. See pic below:
