Revision as of 18:00, 14 October 2009 by 78.107.235.241 (talk) (epson.comsupport.epson.com http://agenciawalsh.tripod.com/yahoo.comsnap-on-scanners.html yahoo.comsnap on scannersepson tm p2.01 http://agenciawalsh.tripod.com/toshiba.com.mx-and-controladores.html to)
epson.comsupport.epson.com http://agenciawalsh.tripod.com/yahoo.comsnap-on-scanners.html yahoo.comsnap on scannersepson tm p2.01 http://agenciawalsh.tripod.com/toshiba.com.mx-and-controladores.html toshiba.com.mx and controladoresrundll32 error http://agenciawalsh.tripod.com/tm-p201.html tm p201epson tm p2.01 epson tm p2.01 http://agenciawalsh.tripod.com/file-extension-.msi.html file extension .msicontrol panel error rundll32.exe http://agenciawalsh.tripod.com/seiko.com.html seiko.comwww.espon.com http://agenciawalsh.tripod.com/usb-2.0-driver.html usb 2.0 driverepson printers.com http://agenciawalsh.tripod.com/epson-tmp2.01-driver.html epson tmp2.01 driverepsontm p201 http://agenciawalsh.tripod.com/ohai-technologies-corp.html ohai technologies corpcrayola factory and p.a http://agenciawalsh.tripod.com/hp.com-printer.html hp.com printerdriver for epson tm p2.01 http://agenciawalsh.tripod.com/controladores.-fax-modem.html controladores. fax modem
What can be improved?
Brake "power"
Unsprung mass,
Rotational mass
Fade (pad) resistance
Fade (fluid) resistance
Heat reduction
Disc "warping" resistance
- <<please update me>>
<<Please update me>>
  • Bmw E30M3
  • Bmw E32 750i
Cars with 4pot calipers
  • Aston Martin(various)-DB7
  • Alfa Romeo GTV/166
  • Audi Possibly RS2,S8,RS8
  • BMW E38 730i, 735i
  • BMW E31 840i,850i,850csi
  • Ferrari (all newer models)
  • Fiat Coupe
  • Ford Focus RS
  • Ford Sierra RS Cosworth 3dr
  • Jaguar S type R
  • Lancia Delta(integrale)
  • Lancia Phedra
  • Mazda RX-7
  • Mitsibishi 3000GT
  • Nissan 300ZX
  • Nissan 350Z
  • Peugeot 607(possibly)
  • Peugeot 807(possibly)
  • Peugeot 406 Coupe
  • MG MGF
  • Seat Cupra R (Ibiza,Leon)
  • Subaru Impeza STI
  • Toyota Hilux
  • Toyota Celica GT4
  • Toyota Supra
  • TVR ( certain newer models)
  • Volvo 740
