Revision as of 06:37, 14 October 2009 by 201.55.165.78 (talk) (joey inc http://cibid.tripod.com/www.walmart.som.html www.walmart.somh. savinuer luggage http://cibid.tripod.com/www.pain-gate.net.html www.pain gate.netwww.sunset golden gate.com http://cibid.tripod.)
joey inc http://cibid.tripod.com/www.walmart.som.html www.walmart.somh. savinuer luggage http://cibid.tripod.com/www.pain-gate.net.html www.pain gate.netwww.sunset golden gate.com http://cibid.tripod.com/kent-glover-carmel-ca.html kent glover carmel cadale h. habeck http://cibid.tripod.com/rapidshare.com-links.html rapidshare.com linksh. savinar luggage http://cibid.tripod.com/florida-dept.-of-agriculture.html florida dept. of agriculturejanine m. winship ca http://cibid.tripod.com/hellom3-yahoo.com.html hellom3 yahoo.comtoon celebs.com http://cibid.tripod.com/celeb.gate.html celeb.gateponcey d. lion http://cibid.tripod.com/california-dept.-of-corrections.html california dept. of correctionsrapidshare.com download tool http://cibid.tripod.com/www2.3wisp.com-amateur-old-austin.html www2.3wisp.com amateur old austincourt.au http://cibid.tripod.com/vanessa-m.-dazio-otd.html vanessa m. dazio otd
What can be improved?
Brake "power"
Unsprung mass,
Rotational mass
Fade (pad) resistance
Fade (fluid) resistance
Heat reduction
Disc "warping" resistance
- <<please update me>>
<<Please update me>>
  • Bmw E30M3
  • Bmw E32 750i
Cars with 4pot calipers
  • Aston Martin(various)-DB7
  • Alfa Romeo GTV/166
  • Audi Possibly RS2,S8,RS8
  • BMW E38 730i, 735i
  • BMW E31 840i,850i,850csi
  • Ferrari (all newer models)
  • Fiat Coupe
  • Ford Focus RS
  • Ford Sierra RS Cosworth 3dr
  • Jaguar S type R
  • Lancia Delta(integrale)
  • Lancia Phedra
  • Mazda RX-7
  • Mitsibishi 3000GT
  • Nissan 300ZX
  • Nissan 350Z
  • Peugeot 607(possibly)
  • Peugeot 807(possibly)
  • Peugeot 406 Coupe
  • MG MGF
  • Seat Cupra R (Ibiza,Leon)
  • Subaru Impeza STI
  • Toyota Hilux
  • Toyota Celica GT4
  • Toyota Supra
  • TVR ( certain newer models)
  • Volvo 740
